Posted by JimB2 on October 15, 2008 at 18:56:12 from (99.241.179.24):
In Reply to: pto on 454 int. posted by robert dingess on October 15, 2008 at 18:15:42:
Hi Robert, check simple things first. Is hydraulic filter clean and lots of hydraulic fluid in transmission? Does power steering and 3pt function properly? Sometimes on that model of tractor the PTO control cable becomes rusty and when you engage the PTO lever fully forward, the control cable does not open the PTO hydraulic valve all the way. The cable runs from PTO lever across behind seat and to PTO hydraulic valve on top of MCV valve by hydraulic filter. There is a rubber boot that can be pried up and penetrating oil applied. Same at PTO lever end. If that doesn't fix the problem then the adjustment of PTO hydraulic pressure to PTO clutch pack requires hydraulic pressure gauge that can read to 250 PSI and some fittings. PTO clutch pack is in the transmission under the seat accessed by the access hole in the transmission under the right floor board. Hydraulic fluid must be drained first.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
