Re: Bolt patterns
Posted by Gearnut on October 15, 2008 at 18:56:58 from (68.62.56.183):
In Reply to: Bolt patterns posted by Tom Windsor on October 15, 2008 at 06:23:43:
CG tractor, I hope more people like you step up to the plate and give these examples of interchangeability and share your knowledge.
In addition, I've learned 300/400 series engines share the same rear bolt pattern... thanks to a fellow puller, Wayne Stine.
Mark Osborne
