Re: broken oiler gear
Posted by Roger46 on October 15, 2008 at 19:46:33 from (69.58.159.23):
In Reply to: broken oiler gear posted by tcouch on October 14, 2008 at 18:32:00:
My theory on why all the oiler gears have their teeth stiped is because if there is any water in the transmission (which there usually is) and it freezes in the winter those aluminum gear teeth will easily strip out when you start the tractor. Once some teeth are striped out, eventually they will all strip out. Roger
