Re: Bolt patterns
Posted by Duner Wi on October 15, 2008 at 19:54:05 from (63.26.127.105):
In Reply to: Bolt patterns posted by gearnut on October 15, 2008 at 06:23:43:
???Does a 263-301 share it's 6 bolt pattern with any other block (actually it's a 8 bolt pattern but only uses 6) ? Someone said a M (264/281) uses the same pattern
answer
The BD and BG truck engines share some parts with the 263-301. Rear of block may be the same/ front I am pretty sure is different.
