Re: Farmall H Knocking
Posted by Bob Frey on October 16, 2008 at 04:37:01 from (74.42.118.103):
In Reply to: Farmall H Knocking posted by Andy Motteberg on October 15, 2008 at 20:56:17:
It wouldn't hurt to disconnect the hydraulic pump to be sure that isn't the source. It's not hard to take the coupling out that is above the inspection plate located just behind the lift-all. This would eliminate the hydraulic pump as the source of noise.
Bob
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
