Re: Farmall H Knocking
Posted by Allan In NE on October 16, 2008 at 04:53:35 from (148.78.243.26):
In Reply to: Farmall H Knocking posted by Andy Motteberg on October 15, 2008 at 20:56:17:
Yep, that "knocking noise" was quite common in the Hs and Ms.
Problem is in the torque tube like has already been stated. Either the pump connector, clutch assembly, or the #1 culprit is usually that driveshaft coupler.
You'll probably have to lower the hydraulic assembly down to get to the bad guy.
Allan
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
