Re: h steering
Posted by Farmall JD on October 16, 2008 at 07:49:06 from (198.208.159.17):
In Reply to: h steering posted by donald schnupper on October 15, 2008 at 15:54:30:
I had the samething with our row crop H. We jacked up the front end and made sure the tires and wheel bearing where tight. Still had the problem. Replaces the front upper and lower bolster bushings and it is nice and smooth now..
