Re: H water pump flange pully
Posted by AH64Dattack on October 16, 2008 at 10:26:11 from (140.153.203.4):
In Reply to: H water pump flange pully posted by littllered on October 16, 2008 at 09:40:37:
Yes you will want to replay both oil seals and if the felt washer is in bad shape I would replace it too. You might also want to replace the packing (45 925 DA) behind the brass nut on the impeller shaft which is right under the fan. I just rebuilt mine and did not replace this packing. But I might wish I did once I get it back on. You can get those seals from NAPA or CASE/IH dealer for about 12 bucks a piece. You can get the water pump off without removing the radiator. Nothing on the pump goes inside the block which would require room to pull it out.
