Re: 1949 M
Posted by El Toro on October 16, 2008 at 16:21:11 from (64.12.116.73):
In Reply to: 1949 M posted by S.Gross(in pa) on October 16, 2008 at 16:01:54:
One advantage with a mag you don't need a fully charged battery since the engine can be hand cranked. With a distributor you need a good battery since cranking the engine will use a lot of that battery power for cranking and may not leave enough battery for the ignition. Hal
