Re: Re: farmall 560 @#$%!! transmissions
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Jim Millar on March 26, 2000 at 17:10:40 from (209.4.82.78):
In Reply to: Re: farmall 560 @#$%!! transmissions posted by COl on March 26, 2000 at 04:46:17:
I think you're describing the situation where more than one gear in engaged, due to a problem with the shifting yokes. You can take the Shift level off the transmission housing, and reset the sliders which the yoke moves. I had to do this once on my 560 and have (so far) not had to do it again. I recall that the slider pattern was obvious and that a simple lever moved things into the right position.
Post A Followup
: Re: Re: Re: farmall 560 @#$%!! transmissions
