Re: TD9 gas/diesel lever is stuck
Posted by Grabatire on October 16, 2008 at 18:10:22 from (74.127.239.29):
In Reply to: TD9 gas/diesel lever is stuck posted by crabbytiger on October 16, 2008 at 18:08:29:
When you say the lever moves out 1/2, is that 1/2 inch or 1/2 the normal travel? If it's the former, it could be the detent on the left side that's the culprit. If it's the later, check on the manifold to see if the shaft on which the flipper is attached, is free. It could be siezed in the manifold. Also check to see if a tiny rock or some object is caught up in the mechanism.
