The W4 does not have a fuel pump. It is a gravity fed system. Start by unhooking the fuel line at the carb to see if you got fuel flow. If you have a good flow, then your problem is in the carb. Check the screen at the inlet of the carb and make sure that isn't plugged.
If you don't have good fuel flow from the line, your problem is in the tank or sediment bowl under the tank. It common for the sediment bowl to become plugged with rust from the gas tank.
