Re: B rear wheel weights
Posted by banjo on October 16, 2008 at 21:02:00 from (65.67.203.29):
In Reply to: Re: B rear wheel weights posted by Zach Bouchard on October 16, 2008 at 09:22:26:
they will probably go on, but not a fit. the wheel is a different contour. Plus the lug nuts will be covered due to the smaller inside hole.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
