Re: Is green anti-freeze OK for a Super A?
Posted by karl f on October 17, 2008 at 06:16:03 from (209.188.106.159):
In Reply to: Re: Is green anti-freeze OK for a Super A? posted by charles todd on October 16, 2008 at 21:19:01:
yes, all antifreeze has anti-rust properties.
Many heavy diesel engine manufacturers require more specialized additives than auto manufacturers.
http://www.peakantifreeze.com/fleetcharge.htm
basically this product in the link contains the same product as the water filter on many IH diesels, purified water, and some other additives. It is ethylene glycol and so is automotive extended life. It's the other additives that differ. Bobcat uses a propylene glycol, which is "safe to drink." it may be required for forestry or food plant uses, but otherwise i see no benefit--you cannot mix the two bases however!!
simple fluids are getting too complicated!
karl f
