Re: Is green anti-freeze OK for a Super A?
Posted by El Toro on October 17, 2008 at 09:12:09 from (205.188.116.73):
In Reply to: Is green anti-freeze OK for a Super A? posted by 56Utility on October 16, 2008 at 20:18:57:
We used Zerone years ago that was alcohol and back then most water cooled engines had thermostats for 160 degrees. Usually would drain it in the spring. When engine temps went to 180 and then 195 you had to use permanent anti-freeze such as Prestone, Peak or Zerex. Permanent doesn't mean forever it just won't boil away. It needs to be changed periodically since it will lose the rust inhibitor. One gallon of raw antifreeze will make 2 gallons of a 50-50 mix and even at todays prices it isn't that expensive and I would stay with the name brands.
Hal
