Re: Is green anti-freeze OK for a Super A?
Posted by 56Utility on October 17, 2008 at 17:48:13 from (65.54.154.116):
In Reply to: Is green anti-freeze OK for a Super A? posted by 56Utility on October 16, 2008 at 20:18:57:
Thank You for all the good information. Yes, my dad's SA has the thermo-syphon cooling (no water pump). I will drain the water out and fill with a 50/50 water/ethylene glycol mix.
Thanks again,
Tim
