Re: 826 hydraulic lever
Posted by Rich Griffin on October 17, 2008 at 19:22:57 from (71.7.10.250):
In Reply to: 826 hydraulic lever posted by lrry on October 17, 2008 at 18:55:13:
Sounds like you have sheared the small pin in the pto hyd.valve which is the piston that goes up and down when you pull the lever. This is a 2 piece item. On some tractors you have to remove pto assy.to get to it. Hope this helps
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
