Re: Cub - to flush or not to flush
Posted by sgtbull on October 17, 2008 at 22:35:17 from (166.159.173.247):
In Reply to: Cub - to flush or not to flush posted by Michael Adams on October 17, 2008 at 04:40:03:
Mike,
I haven't had much good luck w/ JB weld on overflow pipes or similar applications... must be too much vibration If it were mine, I'd plug the bottom, fill it up w/ fresh water to just below where you need to solder, and solder away. There would be so little flammable gas, if any, that it would be safe to torch around, and you wouldn't accidently unsolder your header.
By the way, I got the ck. Have your relatives pick up the implements any time they like.
You don't happen to have an extra drawbar by any chance do you?
