Re: Is green anti-freeze OK for a Super A?
Posted by ddg on October 18, 2008 at 06:54:14 from (66.45.132.217):
In Reply to: Is green anti-freeze OK for a Super A? posted by 56Utility on October 16, 2008 at 20:18:57:
At first glance you'd think railroad locomotive engines are using anti-freeze. It's
green & slick, looks, feels and smells just like antifreeze. But, it's not. It"s just a water treatment. They drop it in in tablet form, and it makes the mixture. (sometimes it"s purple) When we have failures out on the road with these, in freezing temps, we have to manually drain the cooling system, or it will freeze quickly, usually in the radiators first. (The 30 ton engine blocks will hold heat for quite a while) If they shut down and no one is aware, they will auto-drain in about 30 minutes. 250 gallons of steaming green fluid running out the side, seen it many times.
