Re: super m output
Posted by James Rumph on October 18, 2008 at 20:13:56 from (24.192.125.175):
In Reply to: Re: super m output posted by Ed Pap on October 18, 2008 at 19:53:30:
I have a P-400 dyno and we have learned to dyno them between 400 and 540 rpm on the PTO.
Set the timing under full load with a digital tach/timing light, go for the highest rpm under load.
You will be shocked at the HP that can be gained by timing this way.
Put light springs in the Dist. so the weights will give full advance in timing.
