I agree....throw that inline fuel filter away, since they were made for fuel systems that use a fuel pump, and put a new sediment bowl on the tank outlet. Inline filters may be too much flow restriction on a gravity-feed fuel system; while it may not take too much of a pump to overcome an inline filter, you're pretty much stuck with the amount of fuel-flow-inducing gravity you have now.
Then check for a bad gasket, probably between the carb and the manifold, that's allowing the engine to suck too much air for the amount of fuel you're getting. If the manifold and manifold gasket were both good before you had the carb off, odds are they're still OK. But check the simple stuff OUTSIDE of the carb before getting back inside it.
If you have to choke it to make it run, that's an instant sign--yup, here's yer sign--that you're getting more air than needed--or less fuel than needed--in an un-choked mode. Logic says it's either an air leak or a fuel restriction.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
