460 clutch
Posted by CNKS on October 19, 2008 at 14:42:12 from (216.144.104.128):
I installed this rebuilt clutch over a year ago, then moved, just now getting back to it. The old clutch worked ok, but I installed the new one as part of my "restoration". Regardless of adjustment, including the TA, it did not disengage. Split tractor and found a 1/32 deep by 1/8 inch wide groove on the side of the clutch disc that faces the flywheel. I did not have it resurfaced because it looked ok to me -- Wrong! There is a lip next to the inner circumference, that I will have machined out. Will take it to the machine shop tomorrow. Question is I have read of machining the "step" on the flywheel. I assume the step is where the clutch bolts to the flywheel -- should be machined the same amount as the flywheel surfaced is machined?? Also, although the flywheel looks ok otherwise, I have no idea how many times it has been machined, if at all. Is it possible to remove too much with repeated machining so that the clutch does not work right? Tachometer has low hours, but it did not work when I bought the tractor, so I have no idea of usage. Since 99% of the new disc is ok, I do not intend to replace it. Thanks in advance for any replies.
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
