Re: low power in 1947 Cub
Posted by old on October 19, 2008 at 17:16:07 from (4.245.7.175):
In Reply to: low power in 1947 Cub posted by brooksie on October 19, 2008 at 16:33:43:
Running fine before thats one of the problem with the in line filters they clog up fast and with no fuel pump pressure to push the fuel through the filter you slowly slow down the fuel flow to the point you have little or no power which sounds like your problem. Remove the filter and see what happens I'd almost bet you will find power improves. If it doesn't then the carb is clogged up and the filter didn't do you any good any how
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
