Re: 650D bore tolerance and ring end gap
Posted by labman98 on October 20, 2008 at 09:51:39 from (65.216.74.168):
In Reply to: 650D bore tolerance and ring end gap posted by Brad Motheral on October 20, 2008 at 08:53:04:
You can reuse the rod bolts. I would recommend using locktite when installing them. As for the ridge, If it is very much it may be difficult to remove the piston and could damage the rings. If installing new rings I would definately remove the ridge. But a hone will not remove it, you need to use a ridge reamer. Good Luck
