H Overhaul is a Success
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Greg M on March 26, 2000 at 19:35:03 from (205.188.192.48):
Just completed putting the 51 H back together after doing a comlete overhaul. (My first one by the way!) Thought the battery was dead so I gave it a quick up stroke with the hand crank and it hit on all four and almost started! Boy was I suprised. Decided against the hand crank and checked the battery connections again. After cleaning and tightening I hit the starter button (which was also new)and it started right up and showed 65-70 pounds of oil pressure. Ran it for about an hour then shut it down and and retorqued the head and adjusted the valves per the book. Everything is wonderful! By the way, it is a six volt with all new cables and wires and it fires right up on the first or second revolution with just a little choke. Just though I would update you all with my success story. Thanks. Greg
Post A Followup
: Re: H Overhaul is a Success
