It may be necessary to remove that bolt entirely! Take a picture to be sure to keep the positions correct. The bolt must not touch the metal. As noted below, they usually have a small nut on the inside to allow removal (it is still a Pain. Check the distributor shaft for side to side slop. If any it needs a bushing (and possibly a shaft or longer bushing to run on clean shaft) to run at all well. Putting it in High gear on level ground and rocking the engine slowly will let it get to the high point. As will holding in on the fan belt and turning the fan (key off, Plugs out, and in Neutral) JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
