Saginaw on M
Posted by Glen E. on October 20, 2008 at 16:09:34 from (70.41.72.26):
I just installed a saginaw 3 pt. on my 45 M. I ordered the hitch last Monday. They shipped it on Wed. and it arrived in Oklahoma on Friday. That"s faster than UPS or Fed X. I put it on in about 2 hours with a little help from my wife. I was even able to keep the original drawbar intact. Fortunately I have a compact tractor with a loader to do some of the lifting. I bought hoses today and put them on this evening after work. I was anxious to test out the liftall pump so I hooked it up to a grader blade and tested it. It picked it up and held it fine. I then put every suitcase weight I had on the frame of the blade, about 1400+ pounds, plus the weight of the blade. It picked it up without any hesitation and held it when I let off the lever. I was very impressed. I did not think it would work that well. And yes the front end came off the ground when I tried to drive ahead. If anyone is thinking of putting a 3 point on their M the Saginaw hitch is amazing. Absolutely nothing light weight about it.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
