Re: points and condensors.... on 12 v conversion
Posted by Central Illinois on October 20, 2008 at 18:04:32 from (75.105.128.37):
In Reply to: points and condensors.... on 12 v conversion posted by sgtbull on October 20, 2008 at 09:30:45:
I have always just bought a coil that has an internal resistor. Then, put points in like normal. I usually get a coil for a Kohler engine. For example a 10, 12, or 14 horsepower engine. I am sure someone will say this is wrong but I have yet to have a single problem with it. Plus, you won't have to buy the external resistor.
