Re: 364 Hydraulic Problems (full up)
Posted by JimB2 on October 20, 2008 at 18:25:28 from (99.241.179.24):
In Reply to: 364 Hydraulic Problems (full up) posted by BMD on October 20, 2008 at 17:03:37:
Hi on 364 hydraulic system the problem you describe will happen for the following reasons:
1)The draft control level is to far to the rear.
2)The top link spring mechanism has become loose.
Do you have a Operator's Manual? I have one for B414 which has same hydraulic system.
To check the top link mechanism on the rear of the tractor for excessive play. To adjust, look down in the hole in the top of the casting and you will see an adjusting bolt with a slot in the bolt for a screw driver and a jam nut on top of a square block. Loosen jam nut and screw adjust bolt until square block is resting firmly on top of spring below and there is very little play in top link mechanism. The feedback to the draft control sensing is via that chrome plunger beside the top link mechanism.
The other cause is misadjustment of plow and use of hydraulic levers. If the top link is adjusted to long the plow will not dig in and the top link sensing will tell the draft control to raise the plow out of the ground.
Proper use of the hydraulic levers when plowing, when the plow is in the ground push the 3pt lift control all the way forward, then adjust plow depth with depth control and shortening top link. Only use 3pt lift control to lift and drop the plow at the ends of the field. The first furrow will be difficult to start as normally your right rear tire is in the furrow. Once you get the first furrow plowed then you use the crank on the 3pt, top link adjust and depth control to get plow cutting properly. Also some plows have a side hill lever that changes the angle of the plow by rotating the 3pt hitch bar. In most cases just leave it set in the middle where both 3pt hitch pins are vertical to the ground.
Hope this helps
JimB
