Re: IH 444 Tractor Gearbox
Posted by JimB2 on October 20, 2008 at 18:40:03 from (99.241.179.24):
In Reply to: IH 444 Tractor Gearbox posted by JimInOz on October 20, 2008 at 03:16:38:
Hi Jim, it is a two stage clutch. Have you adjusted the clutch to spec?
When you say PTO is hit and miss, are you saying it is difficult to get PTO into gear with clutch pedal all the way to floor board?
On our 434, same as 444 the PTO got difficult to engage and it was the finger adjusting screws on pressure plate had worn a groove in the pressure plate and by rotating each screw 1/4 turn so it was out of the worn groove, fixed the problem. This can be done thru the inspection plate at bottom of bell housing.
Hope this helps
JimB
