I just had mine apart (the hydraulic pump seals were leaking, forcing oil thru the distributor, but that's a whole other story). That pin on mine had a nut on the inside that held the points spring and condenser wire along with two nuts on the out side, one to hold the pin in place, the other to hold the wire to the coil. I just had to loosen the inside nut and pull up on the points and spring and the points came free. If your point spring is under a head, removing both outside nuts should free the pin, but you say you only have one outside nut...hmmm.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
