Posted by Floridaboy on October 21, 2008 at 04:26:50 from (209.149.201.5):
Just wanted to give another update for those that helped. My 674 quit on my while discing. Changed fuel filters, got running, quit on me again. This weekend I took the supply line off above the filters and opened the valve under the tank and had really good flow, so I decided to remove the filters. After removing the filters and line to injector pump I blew air through the bleed hole while blocking the other passages (as best as I could). I got a bunch of black slimy stuff out of the top of the primary side (it hung down like black slime). I removed the assembly, washed in gas and blew out with blow off tool. Put her all back together and less than a minute from turning on the fuel I had a 4-inch stream shooting up out of the bleeder hole. After much cranking, cracking lines to let air out and pressuring tank I got her going. Used her for about an hour and a half with no more problems. I guess when I let the fuel get really low while working it sloshed that black stuff out of the tank and into the filter assembly. Thanks to all that helped with advice.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
