Re: 2424 Brakes Leaking Hi-Tran - how to fix?
Posted by Bob on October 21, 2008 at 06:22:16 from (69.178.228.68):
In Reply to: 2424 Brakes Leaking Hi-Tran - how to fix? posted by Tim in New York on October 21, 2008 at 05:44:54:
Here's a drawing from the CNH site showing the seals, # 14, inside the bull pinion bearing cage, # 12.
14 2 703907R91 SEAL ASSY. SEAL, bearing cage oil, optional w/703908R92
14 2 703908R92 SEAL, OIL SEAL, bearing cage oil, optional w/703907R91
Thankfully, I've never had that problem with my 424, but it sure looks like the cage has to be removed to replace the seals. Apparently, there are shims involved, so pay attention when disassembling it.
Make sure the bearings are not worn/loose so the shaft can move around, affecting the seals.
