Re: Oh Yeah!
Posted by Tims A on October 21, 2008 at 08:51:43 from (13.13.137.1):
In Reply to: Re: Oh Yeah! posted by Andy Motteberg on October 19, 2008 at 16:47:59:
Got it! tried everything per the manual with no luck! Then tried the reverse, throttle at idle, gov. and carb-link moved forward, pin slides in. Then I got throttle up, and idle. Now just to fine tune it. Seems the manual setup would work, assuming the high idle stop was close to where it should be. Test drove got some crud in the carb, applied full choke and sucked it out. I'm good to go.
Thanks, to all.
