I had the same problem with my 424. It is a big job, not that difficult, just time consuming. When you take the brake housing off you can see the seal but you must remove the hydraulic housing under the seat and remove the bull pinion gear in order to remove the bearing cage. This entails removing the axle in order to remove the pinion gear. The parts are heavy so it is good to have some help at least when you are putting it back together. Depending on which side is leaking you may have to remove the pto shaft in order get enough room in the transmission case to move the bull gear and pinion gears. The IT manual should help but it is not completely clear how it all comes apart.Good luck. Dave
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
