Re: Tuesday Night F-20 Mystery: The case of the missing ...
Posted by NE IA on October 21, 2008 at 18:36:28 from (206.72.18.153):
In Reply to: Tuesday Night F-20 Mystery: The case of the missing engine posted by Pete in Holland, MI on October 21, 2008 at 15:50:37:
My ex inlaws had that problem very often, and grandpa showed me how to make a simple fix. Get a pump oil can and fill with kerosen or diesel. Start the tractor and spunk it into the carb intake, just as much as it will take and still keep running. That always lasted for a year or two, then they had to do it again.
If you find it is carbon, just spray with either around the valve stems on a shut off engine. Let it sit with plugs out for a couple hrs before starting.
If neither works, Adjusting or perhaps lapping the valves, or a valve job may be in order.
Today's Featured Article - Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
