Posted by John T on October 21, 2008 at 19:56:00 from (66.244.97.31):
In Reply to: electrical short posted by 2146 north on October 21, 2008 at 16:45:47:
A smoking starter switch could be caused by (among other things) a bad or stuck starter. Once you insure its not mechanically stuck/jammed to the flywheel gears thats causing the smoke, then youre still left with a bad switch or bad starter or cable or connection problems, but since the switch was replaced Ima thinkin more the starter itself (if its NOT a cable or connection problem).
If its a saddle type mount on the starter switch, the copper button/post that comes out the starter may be burned or corroded or carboned up or simply worn down too short n arcing causing problems. If its the stand alone up on the tractor 2 terminal push switch, while the switch may itself be bad, thats NOT the problem described before...
After you remove n clean n wire brush each n every battery n switch n starter n ground connection and if it still smokes, see if when you engage the switch the lights (turned on if it has any lights) dim way down badly and/or the battery voltage drops drastically????????? IF SO (assuming its NOT mechanically stuck/jammed) I SUSPECT THE STARTER IS BAD. HOWEVER if the lights dont dim much or the battery voltage dont drop much n the switch smokes, Ima thinkin more a switch problem, but a new switch should have cured that ????
The starter could have worn bushings allowing the armature to drag the field poles, that will cause excess current draw perhaps causing a switch to smoke and/or the starter to get real hot
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
