Re: electrical short
Posted by John - OH on October 22, 2008 at 04:22:41 from (74.5.133.66):
In Reply to: electrical short posted by 2146 north on October 21, 2008 at 16:45:47:
If switch is smoking, sounds like the contacts are burnt. If the switch comes apart, clean the contacts and see if the smoke disappears. Could also have problems that others described, but I would start with the switch.
