Re: Help solve a Super A question
Posted by glennster on October 22, 2008 at 06:46:17 from (99.131.129.77):
In Reply to: Re: Help solve a Super A question posted by Larry in GA. on October 22, 2008 at 06:39:16:
larry dont try and charge the battery backwards. it will ruin the battery and possibly explode from the hydrogen gasses coming out. i just went thru something like this with my farmall h, 12v pos ground tractor with a genny. neighbor went to borrow it, battery was dead, he jumped it backwards, burned up quite a bit of the wiring harness, along with the genny and voltage regulator. thanks to janicholson here on the board, i got er all back together and charging.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
