IF it's all standard 6volt wiring, the tractor shouldn't be charging the battery backwards. If the battery is disconnected, the generator will lose its polarity and won't charge the batttery until it is repolarized after the battery is hooked back up, and will only polarize in the correct poplarity. To polarize, you need just a jumper or a short piece of insulated wire (so you don't accidentally ground something out!) with the ends stripped back just enough to give you contact. Withthe battery connected and the tractor off, all it takes is a momentary touch between the BAT and GEN terminals on your relay or regulator, which should give you a small harmless spark. That's all there is to it, and the generator, if everything is working, it will charge the battery with the correct polarity. This needs to be done after any time the genrator, the battery or the relay/regulator has been disconnected.
If the battery is flat and you're asking about whether your buddy should hook up a charger backwards because of the positive ground, the answer is NO!!! just as Glennster said. + to + and - to - between the charger and the battery.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
