Re: F-20 Compression Range ?
Posted by the Unforgiven on October 22, 2008 at 08:32:30 from (66.146.251.208):
In Reply to: F-20 Compression Range ? posted by Pete in Holland, MI on October 22, 2008 at 07:34:01:
I think you're probably good enough, all four cylinders being pretty even is a real good sign, I wouldn't fool with it. They are not a high compression engine. Your valves can't be too bad, hose the stems down good while it is running to make sure they aren't sticking, I would guess your intermitent miss is in the ignition.
