Re: mag cap for Farmall A
Posted by ScottyHOMEy on October 22, 2008 at 08:48:22 from (70.105.238.197):
In Reply to: Re: mag cap for Farmall A posted by Bryan Monaco on October 22, 2008 at 07:49:15:
I suppose it's possible that you have another make of mag on there. I've got a tractor book here with a picture of a beautifully painted C on the that has a mag that on it that is very obviously NOT an H4. Wico, FM?? Can't tell an don't know enough to guess. Point is that the H4 would have been factory but it appears that there are others tha will fit/work.
An H4 is pretty easy to identify. It'll have a rectangular bakelite or plastic cover on the top, with the secondary wire running to the cap coming out the rear side of it. The distributor cap is the conventional round configuration. On the body, below the coil cover, it will read a all about being made by IH . . . At the bottom of all that, on a narrow machined flat spot will be a serial number that begins with H4.
If what you've got is nothing like that or enough different, I'm wondering if it might be one of the mags that fit on the F12s or F14s. Try hailing magman on here in a separate post. He'd likely know for sure what the options are for other mags that would fit and help you identify what you have.
