Re: Help solve a Super A question
Posted by Andy Motteberg on October 22, 2008 at 12:00:44 from (4.143.221.179):
In Reply to: Help solve a Super A question posted by Larry in GA. on October 22, 2008 at 05:29:45:
Positive ground from the factory. Does it have a distributor with a coil on top? If it does, look at the wire connected to the terminal on the distributor, the other end of the wire goes onto the coil. If the wire is connected to the negative terminal on the coil, it is negative ground, if it is connected to the positive terminal on the coil, it is positive ground. If the tractor won't run with the battery hooked up correctly, replace the coil. If you have a magneto, you have a different problem. I think if it sat for a couple years, the needle n the carb may be sticking. Check the carb and make sure there is a good flow of fuel into the bowl.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
