Without having seen it, I will say that many in That series have Graphite block Bearings, with a wear plate on the fingers, or built into the bearing, others are traditional ball thrust bearings. Either of these can be pushed to the point that the wear is not causing noise. This may be due to the pressure plate being pushed so far (by the fingers) that they are forced to run true, or the fingers running on a different spot on the bearing. While at intermediate angles they are allowed to be irregular in height, thus the rattly noise and vibrating pedal. Some do this, some don't. Another factor night be the wear on the Throwout bearing guide (which happens most just below the normal point of disengagement. But in either case it is in the bearing that the issue manifests it's ugly head. JimN
