Re: 460 hydraulic pump
Posted by Janicholson on October 22, 2008 at 18:12:20 from (66.173.50.178):
In Reply to: 460 hydraulic pump posted by iowafarmall on October 22, 2008 at 17:45:35:
No issue really.
Put the !3 cylinder on compression (thumb in plug hole to feel pressure start, then rotating until the first timing mark lines up with the pointer.
Then photo the position of the rotor in the distributor (or Mag). Remove said mag/distributor, and lay on a clean cloth out of the way. Photo the drive coupler to assure timing correct.
Get a couple of rubber stoppers to plug up the hydraulic lines when removed. Remove the lines, then remove the pump. Reinstall the pump to assure correct timing. Reinstall the hydraulic lines (with new Orings), reinstall the distributor, and make sure it points in the same exact direction. Static time it and drive away. JimN
