Re: 460 hydraulic pump
Posted by the tractor vet on October 22, 2008 at 20:00:35 from (76.212.239.237):
In Reply to: Re: 460 hydraulic pump posted by bc on October 22, 2008 at 19:20:15:
When ya remove the plate try real hard to save the gskt. and if ya have a set of caliper's then mic. it as the gskt sets the depth of the gear. Now i know that two thins are way tomuch . SO if ya have the thick gskt then you will need to find gskt. paper real close to what was on there and some real thin and amke up the gskt. his is not a hard job and all ya need is a pair of seizors a ballpein hammer ( the smaller the better) IF ya have never made a gskt before then your going to learn something new . Ya use the small end of the hammer to tap over the bolt holes and around the out side edges with the hammer head and it will cut the gskt out with out a problem Do this before ya mount the pumps to the plate then with a pen or pencil and a ruler ya mark it out the inside and cut it out..
