Re: 460 hydraulic pump
Posted by the tractor vet on October 22, 2008 at 20:06:25 from (76.212.239.237):
In Reply to: Re: 460 hydraulic pump posted by bc on October 22, 2008 at 19:26:42:
You won't as it will be a bear just getting the pump plate off . Like i said ya will need a stiff blaede putty knife and a hammer and ya have to drive the putty knife into the corner of the plate and at times it is a fight and that plate also has two dowels and can come off hard.
