Posted by Ben Taylor on October 23, 2008 at 08:31:33 from (138.162.0.42):
In Reply to: locked up engine posted by gary conn on October 22, 2008 at 12:10:54:
I just got a '49 Super A unstuck that had not run for about 15 years. I ended up having to pull the head, spray PB Blaster directly on the pistons and let sit for several days. Most likely (at least in my case) the cylinder(s) that are stuck will not allow any fluid to drain, while the unstuck cylinders will allow fluid to pass. Once I had determined the most probable stuck cylinder, after pulling the oil pan, I used a piece of wood and floor jack to apply pressure directly to the crank at the connecting rod to the stuck piston. The next morning, I applied pressure with the jack to an unstuck piston that would put opposite pressure on the stuck piston, and, with another piece of wood, began tapping on the edge of the stuck piston. After several taps, the engine broke loose. Also, don't give up hope on the interior parts. After subsequently breaking down the engine completely, the only parts I am forced to replace are the rings and bearings...even the sleeves are in good shape. They don't make 'em like they used to!!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
