The pumps on my 2606, which is the same setup as a 460, 560, 660, etc. common to a lot of tractors, are rated at 2250 psi. The relief valve is set at 1600 psi factory. I wouldn't think your pump is any higher. You can google around or check case-ih.com to see if yours has a rating any higher. I don't think on a lot of the older stuff that they ran any 3000 psi pumps so you should be good to go. Even with a higher rated pump, the relief valve can keep it below your rating. I don't think any of the older cylinders were rated any higher than 2500 psi either.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
