Posted by LenNH on October 23, 2008 at 13:20:55 from (24.61.134.129):
In Reply to: F-20 Compression Range ? posted by Pete in Holland, MI on October 22, 2008 at 07:34:01:
All the dual-fuel engines had a "low-compression ratio," probably around 4 to 1, because the higher compression used with gasoline would cause serious knocking with kerosene or distillate. I have never seen this number publicized for the F-20, but there may be someone out here in Tractorland who knows. I have always wondered if the 2-bearing crankshaft would hold up to a 6 to 1 compression ratio (typical for gas). Lots of people got tired of the problems of using kerosene (two fuels needed; a nuisance to start on gas and then switch; need to keep the engine hot for it to run well; need to drain the carb of kerosene if it stalled and cooled off). Everybody I knew with F-20s back in the 40s used gasoline, but with the low compression ratio, I don't suppose the tractor put out too much more power than on kerosene. With a high-compression engine, this thing would be a tiger. It was anyway if on rubber, compared to its performance on steel.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
